× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connectivity Issues
Koolkellygirl
Follower
Connectivity Issues
The unit appears to work, 2ext is green and the arrows are green but none of our computers or tablets will connect to it.  It shows that they connect but there is no Internet.  I have tried resetting and nothing happens.  Shame on Netgear for not having customer support after paying a lot of money for this model
Model: EX7000|AC1900 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Connectivity Issues
Hello Koolkellygirl
If you have the SSID set the same as the router try to change that and then see if the devices will connect. If not try to factory reset the EX7000 by holding the reset button for 10 seconds then do the setup again. Also make sure your routers security type is set to WPA2.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1087 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
