× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Connectivity with Netgear AC750 Dual Band WiFi Mesh Extender Model EX6100v2
arp22
Follower
Just got a new router with a new network name. Have tried all the instructions provided by Netgear but cannot find the installation network named netgear_ext on either my desktop using Windows or my iPhone to complete instructions, any suggestions?
Message 1 of 2
Guru
Re: Connectivity with Netgear AC750 Dual Band WiFi Mesh Extender Model EX6100v2
What router did you install it to?
did you try installing it using wps first?
if so, wps's default installation method is using the mesh function where it has the same ssid as the router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 420 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
