Orbi WiFi 7 RBE973
Reply
D6200
Fols
Follower
D6200
All of a sudden my profile name changed and now my modem is flashing only a red power light with no other lights on the LED panel. What does this mean.
Model: A6200|802.11ac Dual Band WiFi USB Adapter
Message 1 of 3
antinode
Guru
Re: D6200
> All of a sudden my profile name changed [...]
   Ask a moderator?
      https://community.netgear.com/t5/x/x/m-p/1852971
Message 2 of 3
Re: D6200
@Fols wrote:
... now my modem is flashing only a red power light with no other lights on the LED panel. What does this mean.
This is unlikely to have anything to do with whatever profile you are talking about.
More likely that your modem needs fixing. (Get the manual to read what the LEDs mean.)
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
But your subject says D6200 while the footer has "A6200|802.11ac Dual Band WiFi USB Adapter", a very different animal. Is that because you picked the first thing that came up and didn't look for D6200 in the list?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 737 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
