×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Disable Windows Logon
alaland2
Follower
I hate that I have to logon to Windows and want to get rid of it. When I went to Control Panel, Users, Change logon, it told me Netware was controlling client services and I had to change/disable that. Unfortunately, I can't figure out how to do that! I've read until I'm cross-eyed but haven't found a thing about it anywhere on Netgear site or here, so I figure it must be incredibly simple! HELP PLEASE!
:confused:
Thanks!
Message 1 of 2
jmizoguchi
Virtuoso
Re: Disable Windows Logon
XP_FixLogon.exe - Fix Windows® XP Logon/Restore Welcome Screen
© Doug Knox - 03/25/2002
Usage: Download XP_FixLogon.ZIP and save this file to your hard drive. Navigate to where you saved it and double click the file. Extract XP_FixLogon.exe from the zip file and double click it.* The program will tell you if repairs are needed or not.
This utility checks for the correct GINA value in the Registry and will allow you to restore it, if its incorrect.
http://www.dougknox.com/xp/utils/XP_FixLogon.zip
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4518 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
