× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Disable leds on Net gear EX3700
Viggen66
Initiate
Dear all,
I must say I'm quite satisfied with this wifi extender, just to give a glance I get more than 30 mbits on 50% power transmission using fast Lane technology,, I couldn't ask for better.
However, I would like to ask for developers if possible to add on future firmware updates an option to disable leds blicking and disable all leds, mainly because I use the repeater on my bedroom and is annoying all those lights all night long, moreover I know through skimming on this forum, that some models from net gear come with that option on their firmware, is it possible to port it to this device.
Regards
Model: EX3700|N600 WiFi Range Extender
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: Disable leds on Net gear EX3700
Hi @Viggen66,
Welcome to the community!
Glad that you are happy with your device and your input is greatly appreciated. You can post this under the Idea Exchange board on this link.
Dexter
Community Team
Message 2 of 4
Guru
In the meantime, you could put some black electrical tape over the LEDs.
Message 3 of 4
Viggen66
Initiate
Tried putting some white electrical tape, the lights passtrough, only black accomplishes a satisfied results, even though not completely gone
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1068 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
