× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Disable redirection to mywifiext.net
hohn67
Hi,
I own a WN3000RP repeater, and I need to disable the setup wizard.
Sometimes I have to reboot my main router for maintenance purpose and in this case users connected to the repeater are redirected to the setup wizard.
I clearly understand that the setup wizard is helpful for noobs, but in my case this setup is definitely not user friendly: the redirection to mywifiext.net is absolutely not acceptable in an enterprise production environment.
WN3000RP will be the perfect repeater if we could disable this setup wizard in the configuration.
Thanks for your help.
Regards.
Message 1 of 4
jmizoguchi
Virtuoso
Re: Disable redirection to mywifiext.net
Look at open-mesh if you are looking at low cost
Message 2 of 4
hohn67
Hi, Thanks for the reply, so the answer is: "do not buy Netgear for the software but only for the hardware". Ok it's noted.
Message 3 of 4
jmizoguchi
Virtuoso
If that your personal take then that is your choice.
Using consumer level products are usually meant to be at consumer level to setup at ease. You need more configurable products then should look enterprise devices
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 22855 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
