Orbi WiFi 7 RBE973
Reply
Does AC750 require ddwrt firmware to connect to ddwrt-flashed netgear router?
TheSandman
Tutor
This past year my EX3700 hasn't been working properly or at all.
My main Netgear Nighthawk router has ddwrt installed for years.
Does my Wifi Extender need ddwrt firmware installed for the ddwrt router?
Thanks,
tSM
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 2
Guru
Re: Does AC750 require ddwrt firmware to connect to ddwrt-flashed netgear router?
No it doesn't.
If you installed the ex3700 using wps, factory reset it and install it using the installation assistant.
If that doesn't help, a bit more details on whats actually going on helps.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 565 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
