× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Does the NETGEAR Nighthawk X4 AC2200 work well if placed far away from the modem?
pambarletta
I need a dual band wifi extender to reach a room in a basement. The modem is in the ground level, so they will be far apart. Is the NETGEAR Nighthawk X4 AC2200 EX7300 adecuate for this use, or should a go with a NETGEAR Nighthawk AC1900 Desktop WiFi Range Extender (EX7000-100NAS)? Thanks in advance!
Model: EX7300|AC2200 Nighthawk X4 Wall-plug Range Extender
Message 1 of 5
Accepted Solutions
TheEther
Guru
Re: Does the NETGEAR Nighthawk X4 AC2200 work well if placed far away from the modem?
Either will work.  If you go with an extender, be sure to get one that supports Access Point mode.  Not all do.  The EX7000 and EX7300 should be ok, but double check the online manuals.
Message 4 of 5
All Replies
TheEther
Guru
It's impossible to say.  We're talking about Wi-Fi, so there are many factors.  Distance, number and type of walls, radio interference and neighboring Wi-Fi networks can all cause problems.
You would be much better off with a wired connection between the modem and the extender.  An Ethernet connection will be the best, but if you have coax then that will be work using MoCA adapters.
Message 2 of 5
pambarletta
Thank you for your answer TheEther! I have coax connection, so I'll better get 2 Moca Adapters..
Which device should I plug to the Moca adapter in the room I want to bring Wifi to? An extender o a router? Tks! 🙂
Message 3 of 5
TheEther
Guru
Message 4 of 5
pambarletta
Thank you very much!!! I've learned something new today 🙂
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5011 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
