× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
EAP-MSCHAP v2 - Netgear WN3100RP
kasaattila
Dear Community,
I need to know is it possible somehow to set up a known network with the known USERNAME and known Password on the Netgear WN3100RP?
I would boost up the located WiFree signal, but I didn't find any option to give my UserName & Password, it would get only a password, but it is not enough for the connection!
I've got the latest firmware installed on the extender/repeater, but I doesn't find that option 😞 Maybe somebody could tell some trick or hints...
Thanks in advance!
Attila
Message 1 of 3
Accepted Solutions
kasaattila
Re: EAP-MSCHAP v2 - Netgear WN3100RP
Thanks for your help a lot!
Message 3 of 3
All Replies
TheEther
Guru
Looks like you need an extender that supports WPA2 Enterprise.  According to the data sheet (link), the WN3100RP only supports WPA2-PSK.  I don't think any of Netgear's extenders support WPA2 Enterprise.
You may have to use a router that supports DD-WRT (3rd party firmware) to do what you want.  I found a thread on dd-wrt.com that talks about how to set it up (link).
Message 2 of 3
kasaattila
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3703 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
