× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EAX15 in AP mode, WPA2+WPA3 security
tesseract_
Tutor
I have an EAX15 that I was previously using as a mesh extender. It was able to extend my wifi network that was running WPA2+WPA3 security. I now have hardwired Ethernet available so I reconfigured the EAX15 as an access point. It looks like now I have to choose between WPA2 or WPA3 Personal. Is there any way to get the device into mixed security mode when operating as an access point?
Message 1 of 9
Guru
Re: EAX15 in AP mode, WPA2+WPA3 security
I wasn't aware the AP mode removed that option.
What firmware are you on?
I don't have that extender to test with but I know my EAX80 had mixed mode in AP mode because I used it
Message 2 of 9
tesseract_
Tutor
I am on firmware V1.0.3.36. (The latest, as far as I can tell?)
Message 3 of 9
Guru
Looks like you're on the latest.
Got a screensnip of it showing the wpa2 or wpa3 only?
Message 4 of 9
tesseract_
Tutor
Sure, here's what I'm seeing.
Message 5 of 9
Guru
does the 2.4ghz have that option?
What happens if you enable smart connect? Does it give you the option then?
Message 6 of 9
tesseract_
Tutor
2.4GHz has the same list of options.
That is a good thought to check whether enabling Smart Connect makes a difference. Unfortunately, it does not.
Message 7 of 9
Guru
Guess I'll have to break out my EAX80 and put it back in ap mode to see if its specific to your device or that line of devices. I could swear it had mixed mode.
Message 8 of 9
Guru
You're right. Mine is the same in AP mode on my EAX80. No mixed wpa2/wpa3 mode. It doesn't make sense not to have that but to have a wpa/wpa2 mode. It's a super outdated, hacked security method option. Huh. Wonder if there are any mod's still watching the extender forums, as that shouldn't be an option and wpa2/wpa3 should be.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 654 views
  • 5 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
