- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EAX20 - Connect Extender to Multiple Routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the onset of Work From Home (WFH), there is a huge need to have a backup for your main routers. I have 2 routers at home, one is a Netgear Nighthawk that uses a fiber optic connection and the other one is a sim-based 4G Dongle.
Is it possible to extend both these routers using one extender - to behave like an auto failover mechnism??
If one of the router is down, it should automatically switch over to the next available router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EAX20 - Connect Extender to Multiple Routers
Unlikely, but questions about extenders might be best tried in the section given over to extenders. This one is for Nighthawk WiFi Routers.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P- Mark as New
- Bookmark
- Subscribe
- Permalink
No, there's not a way to set that up.
It'd be ideal but there isn't that function.
What might be a better option for you is a failover/load balancing router.
You'd connect your 2 ISP setups to that and then connect the router to it. then the router would always have service.
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
