Reply
EAX20 Firmware 1.0.0.58 Update Error
EAX20 indicates there is a firmware version 1.0.0.58 update available. However the firmware update will not complete whether using the Nighthawk app or an internet browser. My current firmware version is 1.0.0.52.
Message 1 of 6
Accepted Solutions
Guru
Re: EAX20 Firmware 1.0.0.58 Update Error
what error are you getting when you try it manually?
How do I manually update the firmware on my NETGEAR WiFi Extender? | Answer | NETGEAR Support
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 6
All Replies
Guru
Message 2 of 6
bbandor
Guide
I have the exact same problem, I didn’t try the manual update
Message 3 of 6
When I made this post, the firmware wasn’t available for download on the support website. Now it is available for download and the manual update worked fine. The auto-update, including the nighthawk app, failed to work.
Message 4 of 6
Kevin84
Hello,
I do experience the same issue : the new firmware can be downloaded form the mobile app, but it cannot get installed.
In fact the repeater seems to not be able to reboot, even from the mobile app reboot option.
I have also tryied with the manual update, but in this case in cannot succeed to log in.(wrong credentials)
The issue percists after factory reset.
Thanks for your support
Regards
Message 5 of 6
Download the new firmware, perform a factory reset and setup your extender without performing an automatic update. When your extender tries to automatically update the firmware during the new extender setup process, type in the IP address of the extender and login as usual. After you’ve logged in, update your firmware manually. Here’s a link to the firmware download page: https://www.netgear.com/support/product/eax20.aspx#download
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 890 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
