PaulGo's avatar
PaulGo
Luminary
Jan 20, 2023
EAX20 In Mesh Mode - WiFi Probelm With Mobile Devices
For mobile devices such as a smartphone, instead of transitioning to the EAX20 so when near the EAX20 the signal from the EAX20 conflicts with the router signal and causes very poor speed. The only way to fix this is to stop Wi-Fi and then resume Wi-Fi on the smartphone so it with now connect with the RAX20. For stationary items such as TVs and Roku devices, it works fine. I am useing the latest firmware available.
  • plemans's avatar
    its not the extender or the router that causes phones/tablets/etc to roam but their own roaming protocols. We can't fix their roaming protocols sadly.
    What phone do you have?
    Do you have it up to date on its own firmware/software?
    Sometimes if the extender it to close to the router, it can cause roaming issues as well as the phone still picks up the router signal fine (per its own protocol)
    • PaulGo's avatar
      PaulGo
      Luminary
      I have trhe Samsung S21 smartphone running Android OS 13 which the latest updates. The S21 has Wi-Fi 6. The EAX20 is about 35 feet away from my Netgear RAX54S router. When connected to the RAX54S at close range I get over 600 Mbps and when connected to the EAX20 I can get close to 300 Mbps. When connected to both I get 20 Mbps.
      • plemans's avatar
        If the router is putting out 600mbps, the 300mbps you get from the EAX20 is normal. Extenders by how they work drop throughput 50%.
        this happens because they have to use the same chip for single/dual band extenders to go router----extender and then extender----device. And it can't do both at once. So if you're getting 300mbps when connected to the EAX20 and 600mbps with the router, thats normal.
        I have no idea what you mean by 20mbps when connected to both. You can't connect to both at once.
