- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EAX80
- Mark as New
- Bookmark
- Subscribe
- Permalink
EAX80
i am having some issue between my rax120 and my rax80 everthing is fine on the 2.4Ghz in ax mode on the eax80 but on the 5Ghz i am having upload speed issues, but if i have my rax120 in AC/ wifi 5 mode and the eax80 in wifi 6 the upload speed out of the eax80 is normal the same aswell with the rax120 in wifi 6 mode and the eax in ac / wifi 5 the only issue i am having is when both devices are both have wifi 6 enabled and seeing below 1mbps on the upload of the 5Ghz on the eax80. everything perfect in acsess point both 2.4Ghz and 5Ghz channes have full download and upload speeds on the eax80. in fast line mode same happens 2.4Ghz in 5Ghz out perfect but 5Ghz in and 2.4Ghz out has the same upload speed issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EAX80
The Netgear Nighthawk AX12 12-Stream AX6000 WiFi 6 Router (model RAX120) is my second Wi-Fi 6 router, after the Asus RT-AX88U , yet it feels like the first. That’s because I didn’t have a Wi-Fi 6 client to test the Asus. I do now, thanks to Intel’s newly released AX200 adapter card which is an easy Wi-Fi 6 upgrade .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EAX80
Issue Resolved Sine Latest Update Just Now Need To Figar Out Why When Not Level With Other Router Speeds 5% slower
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EAX80
@john070102 wrote:The Netgear Nighthawk AX12 12-Stream AX6000 WiFi 6 Router (model RAX120) is my second WiFi 6 router, after the Asus RT-AX88U , yet it feels like the first. That’s because I didn’t have a mybkexperience Wi-Fi 6 client to test the Asus. I do now, thanks to Intel’s newly released AX200 adapter card which is an easy Wi-Fi 6 upgrade .
It is really a good router and I must appreciate that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EAX80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EAX80
When you log in to the EAX80 Web ui what's the link speed between Your RAX120 and EAX80 ? Ive been recently experimenting with all settings on RAX120 i disabled PMF in dvanced Wifi settings I was able to get round about 750mbps from my EAX80 to a wifi 6 enabled client othern than that hard wiring it as a ap gived you full speed i tryed ap mode and got 940mbps
