Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ERROR - 'default gateway is not available'
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-08-31
12:42 PM
2012-08-31
12:42 PM
Just installed new WN802T Access Point. Previous network connections provided by Centurylink DSL modem w/built in wireless worked fine.
But with the WN802T, I get "default gateway is not available". Windows 7 trouble shooter will fix the problem but it will reoccur. Wireless network will show as "connected" but without access.
This is in a small business enviroment.
thanks in advance for your help.
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-05
08:58 AM
2012-09-05
08:58 AM
Re: ERROR - 'default gateway is not available'
wn802t is just access point..
what is your current router
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-05
10:50 AM
2012-09-05
10:50 AM
Here's my configuration:
DSL in -> DSL Modem -> SonicWall TX180 -> NetGear 24 port switch -> several wired PC's, printers & NetGear WN802t Access Point -> 3 Laptops.
I have one Dell laptop that has no problems. But there are 2 HP Envy 15-3040nr laptops that will connect and work for a few minutes but then loose access even though they still show a connection.
I suspect that it's an issue with the HP laptops. All three of the laptops are running Windows 7.
When hardwired, they work fine.
Doug
Doug
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-05
11:59 AM
2012-09-05
11:59 AM
I would just setup static IP instead
Message 4 of 4
Announcements
