- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX 3700 alway gets in big trouble with my Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have big problems with my extender. Setting it up, is easy, including the *ext-name of the extender and so on. Also how it increases the WiFi-signal - but: After a few hours in use, all(!) of my WiFi-using devices (Laptop, smartphone etc.) will not work properly with the networks: I´ll have to switch the networks, from the original one (directly from the Router) to the extended one. I´ll get bad connection to the internet - all in all it is abolutely unstable. It seems to me, that the Router and the extender dom´t work together very well. Even some devices won´t be able to connect to the internet, at all. Finally, I´ll have to switch off the extender and re-connect them to the Router to make them connect.
My Router is a Fritz-box.
Any ideas?
Thanks
Sven
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX 3700 alway gets in big trouble with my Router
Hello Sven_Hansel
Have you made sure your extender and router have the latest firmware?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren,
thanks for your support.
Updated to Firmwareversion: V1.0.0.58_1.0.38
Will see, if that helps. 🙂
Cheers
Sven
