× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX 8000 - does it support 160 mhz channel for use with intel 9260 160 mhz?
thehulk
firmware: V1.0.1.180
model : ex8000
region: north america
how can i make use of the 1.73 gbs 5ghz channel in ap mode?
i am currently using intel 9260 160 mhz which is capable of 1.73 gbs.
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Range Extender
Message 1 of 5
Christian_R
NETGEAR Employee Retired
Re: EX 8000 - does it support 160 mhz channel for use with intel 9260 160 mhz?
Hello thehulk - The 1.73gbs  is dedicated to the backhaul connection only and is inaccessible.
~Christian
Message 2 of 5
schumaku
Guru
That's an expensive loss of capability in AP mode isn't it?
Message 3 of 5
thehulk
Then why do i have an option to change radio 3 (5 Ghz) to 1.7 Gbs speed if it is inaccessable?
There must be a way to achieve 1.7 Gbs or the option should not exist in ap mode.
Message 4 of 5
schumaku
Guru
HT160 and MU-MIMO are two things where not all chipsets as created equal in. The problem is that the Inhell 9260 is a 2x2 system while the AP is a 4x4 - there are several interoperability issues probably still prohibiting a fully fledged 160 MHz connection on a linear channel group or a mixed channel group and when it comes on joining a MU group. Qualcomm (as used in the EX8000) seems to be better at the moment in terms of a fully functional WiFi router chipset. Haven't re-tested recently - not so long ago the 9260 was not able to work on a 80+80 MHz channel set as we have in Europe for example connecting to the Netgear R9000, too.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1219 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
