- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX2700 - Connectivity issues with Devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just tried to set up my extender. 3/4 of the lights are green... Power light is green, WPS is green, and Router is green, but device will not light green, it doesnt light up at all, even red. When i go into my wifi networks, it does not appear that the extended network (my network_EXT) has been created that the directions say should be there.
I followed all directions, but i must be doing something wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX2700 - Connectivity issues with Devices
If you are seeing NETGEAR_EXT, then join that (it should be open). Then complete the setup by browsing to mywifiext.net.
If you aren't seeing that, then reset the extender and try again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not seeing any option for an EXT network, my own or the netgear one. I have reset to factory settings 3 times.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think something is wrong with the extender hardware.
If this is a new purchase, see if you can exchange it with the seller. If that is not possible, you can do an RMA through netgear support (my.netgear.com).
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
