× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX2700 EXTENDER
Dynotech
Follower
EX2700 EXTENDER
Hello, I've just installed the extender, all lights are green, so I'm connected to the router. When I try to connect with laptop or my phone, it connects with a green light for a few seconds then disconnects. What am I doing wrong???
Thanks for help
Message 1 of 2
Guru
Re: EX2700 EXTENDER
What router is it connected to?
Did you install using the WPS (push button) method?
If so, factory reset the extender and try installing it using the installation assistant. WPS doesn't always get coded the same and can cause issues. This is where the installation assistant comes in.
Message 2 of 2
Discussion stats
  • 1 reply
  • 257 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
