Reply
EX2700 Range Extender Essentials Edition
JonMP64
Follower
I have purchased the EX2700 Range Extender UK version, three pin plug, can I use this in Jamaica with a simple plug adapter? Thanks
Message 1 of 2
Accepted Solutions
Guru
Re: EX2700 Range Extender Essentials Edition
If the power (voltage/hz) is the same, you should be able to but you might need to change the region code so you're not in violation of regional broadcast issues.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 146 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
