× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX2700 can not "see" my router Network
desertsailor
Initiate
My EX 2700 extender was working nicely with my TP-Link Archer C9.  It stopped connecting after I made a reboot of my router.  The extender keeps failing to make a connection through WPS.  When using the Netgear setup webpage, the extender can "see" all my neighbors home networks but not mine!
I have a spare brand new EX3700 which I tried to use but I faced the same problem.
I would appreciate any help.
Thanks
Message 1 of 3
Accepted Solutions
Guru
Re: EX2700 can not "see" my router Network
What 2.4ghz wireless channel is the C9 broadcasting on?
Try changing it to 1-6-11.
Message 2 of 3
All Replies
Guru
Message 2 of 3
desertsailor
Initiate
WOW!!
That did it. I had switched to ch.13 to help reduce interference from neighbors 😅.
Thank you very much for your help.
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 726 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
