× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX2700 low speed
Salvatretzzo
EX2700 low speed
Low speed
Hi yesterday recive this product, my home speed connection is 100/10 Mbps, the router is in the living room and wifi extender in my room(look the screen I dont have my pc right now) the red circule is the router and point blue the extender, my problem is if connect any device in my room to the router my soeed test is like 60 Mbps, with extender 6 Mbps! I buy this device becouse I want recive all my speed in my room and recive a lot less, I connect the extender in living room same place router and speed is 30 Mbps extender and 95 Mbps the router, I set up with WPS, restore to factory and set up with browser And the problem continues, I change the Channel, Change SSID, Restore router to factory reset...
please help!!!
router is rhe red and extender the blue
[URL=http://www.imagebam.com/image/a00d75520018215][IMG]http://thumbnails117.imagebam.com/52002/a00d75520...]
connect to my router in my room
[URL=http://www.imagebam.com/image/7d3928520018325][IMG]http://thumbnails117.imagebam.com/52002/7d3928520...]
connect to ext in my room
[URL=http://www.imagebam.com/image/8bf76e520018319][IMG]http://thumbnails117.imagebam.com/52002/8bf76e520...]
[URL=http://www.imagebam.com/image/2b1812520018326][IMG]http://thumbnails117.imagebam.com/52002/2b1812520...] [URL=http://www.imagebam.com/image/2f43b9520018328][IMG]http://thumbnails117.imagebam.com/52002/2f43b9520...] [URL=http://www.imagebam.com/image/af6fcf520018334][IMG]http://thumbnails117.imagebam.com/52002/af6fcf520...] [URL=http://www.imagebam.com/image/17d45b520018337][IMG]http://thumbnails117.imagebam.com/52002/17d45b520...] [URL=http://www.imagebam.com/image/5566bc520018339][IMG]http://thumbnails117.imagebam.com/52002/5566bc520...]
Message 1 of 3
Salvatretzzo
Re: EX2700 low speed
someone can help me?
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
Hello Salvatertzzo
If your extender is connected via wireless then you will not get the same speed as you are getting from your main router. The signal can be up to half the speed loss of your main router. Also the materials in the home and wifi interference can cause speed loss.
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2807 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
