× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX2700 slow download speed. Should I upgrade?
daniel0824
Follower
Hello there.
I think my EX2700 extender's speed has gone down recently.
I used to be able to get a decent speed of around 10 Mbps, now it's quite unstable.
Sometimes I even get down to 3 Mbps.
However, if I connect to my Wi-Fi directly to the main router (in the same place in my room as I connected to the extender), the speed is good but the ping takes somewhat longer.
I'm not sure if this has to do with my neighbour's Wi-Fi upstairs.
I have already changed my channel to be as far away as all the other occupied channels as possible (Their channel is 3 and mine is 13).
Would upgrading my extender to a dual band AC750 (like the EX3700) help with the situation?
The advertised speed from my current ISP is 19Mbps. I am switching to another ISP with 57Mbps soon so I am also wondering if I should get a better extender to catch up with the faster speed.
Model: EX2700|N300 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: EX2700 slow download speed. Should I upgrade?
Upgrading could help if you are using a 5ghz connection on your router you may be able to get better speeds out of the extender.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3135 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
