- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX2700 unable to connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Netgear EX2700 that used to work great. I have an Amazon device at the far end of the house and relocated the extender to that end. I am unable to get any device to connect wirelessly to the extender now.
I plugged the extender into a power outlet in the same room as my router and used the WPS buttons to have it connect. All of the lights are showing green, but I am unable to connect to it with a browser on my ethernet connected desktop or my cell phone. I did a factory reset and then pressed the WPS buttons and it looks like it connected to my router again as all lights are solid green again.
But, I am unable to connect to the extender with any device. Another weird issue is that the MAC address on the device does not exactly show on my router logins. It is off by 1 letter.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX2700 unable to connect
Good move to do it in the same room. Set up the extender and then move it.
What is the router? Did you tell it to forget the extender's earlier connection?
Can you get it to work without using WPS?
These things can create more than one MAC address, for different wifi connections.
When you do get it to work, a better location might be in the middle of the gap between the router and the Amazon device.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
You might like to search there for messages related to your problem.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
