× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX2700
nat58
Follower
EX2700
HI I just purchased a Netgear Ex2700 wifi extender.  I have a motorola SURFboard  SBG6580 router.  I tried connecting with WPS but I couldn't because  the router dosen't have a WPS button.  So I resetted the WIFi extender to factory settings.  I then tried the Web Brower setup I used a WiFi manager to connect to the extender the device link led lights up,  but the Netgear genie dosen't automatically startup.  So when I type the www.mywifiext.net in my browser I get an error message that I can't find this page.  What do I do now.  Also when I tried downloading the firmware for this device and tried installing It says that the file is corrupt and it says this for every version I tried to install.  Thanks for all your help.
Message 1 of 2
TheEther
Guru
Re: EX2700
According to the SBG6580 Quick Start Guide, the WPS button is on the front panel near the bottom.
Message 2 of 2
Discussion stats
  • 1 reply
  • 2866 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
