× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX2700
HNot
Tutor
EX2700
Hello,
I have recently purchased the EX2700 wifi extender and have set it up correctly, the WPS and router LEDs are both solid green. However, when I try to connect my phone to the extended connection with the same password for my router, it says "incorrect password". I've tried multiple times in different locations, but still isn't working. Is there any way of getting around this?
Hopefully someone can help, thanks!
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 6
Accepted Solutions
Guru
Re: EX2700
what router are you connecting it to?
have you tried installing it with the installation assistant and not using wps?
WPS can get coded different between manufacturers and cause issues. If it does, thats when we recommend factory resetting the extender and installing with the assistant.
Message 2 of 6
All Replies
Guru
Re: EX2700
Message 2 of 6
HNot
Tutor
Re: EX2700
I am connecting it to a Technicolor router, I think with a modle number of DGA4231.
I haven't tried using the installation assisstant but I can give it a go
Message 3 of 6
Guru
Re: EX2700
let me know how the installation assistant goes
Message 4 of 6
HNot
Tutor
Re: EX2700
the installation assisstant worked perfectly!
Thank you
Message 5 of 6
Guru
Re: EX2700
Glad to hear it worked!
Message 6 of 6
Discussion stats
  • 5 replies
  • 1097 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
