× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX300 wifi extender : WPS led never be solid green
egarouf
Follower
Hie
I connected my extender following the "connect with WPS" way.
It seems to work fine but the WPS led never be solid green ...
Does it mean that WiFi security is not enabled ?
If so, how can I do to activate security ?
Thanks a lot
Message 1 of 2
olympos1625
NETGEAR Employee Retired
Re: EX300 wifi extender : WPS led never be solid green
Hi egarouf,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for not being able to get back to you immediately due to system backlogs. WPS is always light up( blinking or solid). WPS doesn't relate to the wireless security of your extender. If it requires a password to connect to your wireless extender, it means that it's secured. During the setup, you are asked to enter the wireless security of the router, it allows you to select your own wireless settings or copy the wireless settings of your main router.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 465 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
