×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
EX3110
ebok
Follower
EX3110
the wifi network name isnt showing. What can i do to fix this? It has been connected to the router fine and the wps is working properly
Message 1 of 3
Guru
Re: EX3110
Have you tried installing it using the installation assistant and not WPS?
Try factory resetting it and installing it with the assistant
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
nielsvds
Luminary
Re: EX3110
See if you didn't uncheck disable SSID broadcast see pages 18-19 of the manual : https://www.downloads.netgear.com/files/GDC/EX3110/EX3110_UM_EN.pdf
That option should be checked SSID broadcast. Navigate to mywifi[DOT]net to get into the configuration page of yoru extender.
Message 3 of 3
Discussion stats
  • 2 replies
  • 306 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
