× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX3700 Router Link Light
Ryan21
Hey I brought the ex3700 wifi range extender and worked perfectly but I took it out for about 3 days and now the router link goes red after 15mins of putting it in and the device link goes yellow a few times even though I'm right next to it I've tried resetting and reconnecting but nothing works
Message 1 of 6
Guru
Re: EX3700 Router Link Light
What Mfr and model # router are you using with the EX?
What FW is loaded on the EX?
What is the distance between the main host router and EX?
Message 2 of 6
Ryan21
Wireless
NETGEAR EX3700-100UKS Wi-Fi Range Extender AC750
It's about 12 foot away from this wifi box
Message 3 of 6
Guru
12 feet maybe too close.
Try 30 feet from the main host router?
Message 4 of 6
Ryan21
I cant really go any further don't see how that would work but its says I need to get closer but I've had it in this position for months and worked great until I turned it off for a few days
Message 5 of 6
Guru
Possibly the unit maybe bad now. Having wifi too close has probably burned out the internal components over time.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1035 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
