robinsubar1's avatar
robinsubar1
Follower
Mar 06, 2022
EX3700 password
I am simply trying to change the password on my EX-3700, or figure out what it is.  I cannot log on to the site "my wifi ext" or the dot.com site as it times out when I try.  Is there any way to reset and set up without the browser?  Otherwise this is junk.  Thank you!
1 Reply
  • FURRYe38's avatar
    You may want to look at the installation guide or user manual for the EX extender to help you with this.
    A factory reset maybe needed and walk thru the setup wizard and be sure to write down all important information for safe keeping and use later on.
