× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX37000
Netbobby
EX37000
Recently bought a new Wifi  Range Extender, set it up no problem at first. Now the router led goes red. Turn it off turn it on works for 5mins then goes red again.
Message 1 of 4
Guru
Re: EX37000
what router did you connect it to?
Did you set it up via wps or using the installation wizard?
what firmware is on the extender?
Message 2 of 4
Netbobby
Re: EX37000
Linked to a Virgin Router
Coupled us WPS
Its brand new so assume firmware/software up to date
Message 3 of 4
Guru
Re: EX37000
@Netbobby wrote:
Linked to a Virgin Router---Not very specific as they have many routers. Which one?
Coupled us WPS-----try installing with the installation wizard and not wps. wps gets coded different between manufacturers.
Its brand new so assume firmware/software up to date-----brand new usually means it doesn't have the latest as firmware gets updated after its been made/boxed/shipped. And a number helps for anyone else with this issue.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 501 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
