× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX6100 EXTENDER PASSWORD
shrmnmrk
Tutor
I moved my office to my home and took my EX6100 with me.  I did factory reset and connected to my home Nighthawk router, setting up the _EXT wifi network.
Unfortunately I am unable to log in to the extended network from either my pc or iphone.
Please help.
Thanks
Mark
Message 1 of 12
Guru
Re: EX6100 EXTENDER PASSWORD
Unable to log into it?
do you mean connect to the wifi or logging into its browser to access it?
What router did you connect it to?
What modem/gateway is your router connected to?
I'd recommend setting it up using the installation assistant and not wps.
Message 2 of 12
shrmnmrk
Tutor
Both my iphone and my pc see the EXT wifi network but my password does not work
Connected to my Netgear Nighthawk
Please direct me to that "installation assistant."
Thanks
Mark
Message 3 of 12
Guru
saying netgear nighthawk is like someone what car you drive and saying ford. There's a lot of different nighthawks so a model number helps.
Same with the modem/gateway model. We see double nat's (cascading more than 1 router) and it can cause issues.
in terms of the installation assistant:
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 4 of 12
shrmnmrk
Tutor
I am attempting to connect my Netgear EX6100 Extender to my
NETGEAR Nighthawk Smart WiFi Router (R6700) - AC1750.
I have followed the instructions for the installation assistant:
I opened the Network connection manager (0:20 on the video).
I do not see a network called "NETGEAR_EXT."
I do see a network called "EX6100_NETGEAR_2GEXT."
I seem to be able to connect to that network, but when I go to mywifi ext.net
I get this message:
"You are not connected to your extender's WiFi network."
Your assistance will be most appreciated.
Thanks
Mark
Message 5 of 12
Guru
Have you tried setting it up before? That isn't the default ssid.
Plus if you're connected to the extenders ssid and its giving you that notice, it usually means its connected to the router.
Log into the router and look at its attached device page. If the extender is connected, it should have an ip address on that page. Use that ip address to access it.
Message 6 of 12
shrmnmrk
Tutor
Yes. I had it working at my office, then I moved it into my home.  I did factory twice.
I am a bit confused. Please give me specific instructions to "log into the router."
Thanks
Mark
Message 7 of 12
Guru
Not sure what router you have but you can usually access them using a browser interface to change the routers settings.
From within that interference, there tends to be an attached devices page (or equivalent)
without knowing what router you connected it to, its tough to be specific on telling you how to access it but the routers user manual should go over how to access it using a web browser.
Message 8 of 12
shrmnmrk
Tutor
Thanks for your reply.
The router is:
Mark
Message 9 of 12
Guru
try going to routerlogin . com  or 192.168.1.1
log into the router there and then go to the attached devices page.
Message 10 of 12
shrmnmrk
Tutor
Ok, now I see the attached devices.
Should I see the Extender there? I do not.
Thanks
Mark
Message 11 of 12
Guru
If its connected to the router, it should show up there. It might not say netgear extender under the description.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1395 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
