- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6100 WiFi Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to follow Netgear's directions for upgrading the Firmware on my EX6100 range extender. First, how do I check which Firmware version is running on it and second, if it requires a new Firmware update, what is the easiest way to accomplish this. It seems as though Netgear provides various instructions for doing these Firmware upgrades, but when I access the links provided nothing happens. Is there an easier process to follow to check the Firmware version and upgrade it if required. Thank you for your feedback and support. Gary Wasson
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6100 WiFi Extender
The support site literal has a video showing using the upgrade assistant and using the manual method. I'd take a look at both
https://www.netgear.com/support/product/EX6100.aspx
simply click the > on the video's to see the other versions.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
