- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6100 ethernet output connect to router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have shed on the end of my property, I had put an EX6100 & my garage to be able to access the internet in the shed & improve connectivity in my house.
This worked for several years, but now I am stuggling to connect & when I can, speeds are slow in the shed. I had thought to run ethernet from the ethernet connection to the shed & then place a device to provide local wifi in the shed. I had an old router & thought if I took the output & run it into a LAN port it might work, but it will not let me access the internet.
Is this possible or do I need another 6100 configured as an access port?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
Thanks for the reply. I finally got it to work. The EX6100 was working fine. I had to fix the configuration of the router.
BUT lesson learned, The old router is a linksys wireless G & the outlet is switched. I mean that the power to the outlet is controlled by a light switch. I found that the linksys router apparently has no nonvolatile memory because even though I pulled the barrel plug in & out of the router several times with no ill effects, when I returned to the setup after having the power to the router turned off for a couple of hours, it had completely lost it's settings. A web search yielded numerous people describing the same thing. It sounds like Linksys uses a capacitor to retain settings instead of EEPROM! Another good reason to buy Linksys
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6100 ethernet output connect to router?
Hi @bobmounger, what is the firmware version of the EX6100? Is it setup in AP mode or extender mode? Yes, it is possible. Are your devices still getting a strong signal from the extender when you're in the shed?
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dexter,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oops. I mean NOT to buy Linksys
