- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6110 Device Connects But Continually No Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
All green lights on EX6110. Devices connect to EX6110 but one (Asus Laptop) continually says No Internet. This used to work. Tried resetting everything from Fibre termination, router, EX6110 and laptop concerned to no avail.
Any ideas on how to troubleshoot welcome
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So it said DHCP automatic - changed it to manual and back to automatic and it now seems to be working - did something just have itself confused? IPConfig now looks betterer:
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : home
Wireless LAN adapter Local Area Connection* 1:
Wireless LAN adapter Local Area Connection* 2:
Ethernet adapter Ethernet 2:
Wireless LAN adapter Wi-Fi:
IPv4 Address. . . . . . . . . . . : 192.168.0.23
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6110 Device Connects But Continually No Internet
What router is it connected to?
Firmware on the extender?
Did you set it up using the wps install method or using the installation wizard?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's connected to an Optus Sagemcom 3864V3. Not sure on firmware - will check, and setup was so long ago I can't remember. I would stress other devices connect to it and use Internet fine, and this laptop used to. This laptop still connects to every other w/less network just fine. Is it worth trying a firmware update (if there is one).....just checked and it said firmware is up to date....
Also apparently it's an EX 3110 if that makes any difference....
- Mark as New
- Bookmark
- Subscribe
- Permalink
IP Config on Laptop connected to extender (no internet:
Autoconfiguration IPv4 Address. . : 169.254.123.2
Subnet Mask . . . . . . . . . . . : 255.255.0.0
IPConfig on same laptop connected to Router (and internet)
IPv4 Address. . . . . . . . . . . : 192.168.0.12
- Mark as New
- Bookmark
- Subscribe
- Permalink
