FurHead's avatar
FurHead
EX6110 Entering correct Password when connecting device but won;t connect says password is wrong
I have set up my range extender and it has connected succesfully with my router. When trying to connect to my extender, for both the 2GEXT and 5 GEXT bands then the password of the router is entered (as the instructions tell you to do so) on the device is entered, but it won't connect to the extender because it says the password is wrong.
It use to work on my old router but not with my new router.
How do I fix this?
  • plemans's avatar
    If you hardwire into the extender and type mywifiext.net you should be able to access the settings page. From there you can control the ssid and password. I'd make sure the password is indeed correct that you're entering.
    • FurHead's avatar
      FurHead
      Hi Plemans,
      Thanks for that solution. However, how do I hard wire to the EX6110 extender. There doesn't seem to be a USB port or similar on it to connect to?
      • plemans's avatar
        Sorry. Was thinking of a different model
