× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6110 I can’t connect to the wifi, no device can connect.
ayri06
Follower
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: EX6110 I can’t connect to the wifi, no device can connect.
Well more info is needed.
1. Where is the process failing? Are you struggling to connect to your extenders wifi or getting the extender to connect to your router's wifi? More details that "it won't connect" is needed. Expand on the questions I've asked. the more you tell us, the better we can help you
2. What firmware is on your extender?
3. What router are you connecting to?
have you went to your support site? It has manuals, firmware, install guides (with videos), and troubleshooting. Its a great resource.
https://www.netgear.com/support/product/EX6110.aspx
Message 2 of 2
Discussion stats
  • 1 reply
  • 682 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
