- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6120 Firmware Update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using the EX6120 without any problems for a couple of years, but after a move I had to reinstall my network and did an update on the firmware as well. Done this update, the unit is working properly in the network, but I cannot access via the Web browser anymore. The firmware installed actually is version 1.0.0.54
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
when you're trying to access it are you using the mywifiext . net or the ip address?
Try logging into the speedport and finding the IP address for the extender and use that to connect to it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6120 Firmware Update
what modem/gateway did you connect it to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to ensure: the extender is working in my network, ie I can use as an AP but to access the unit themselves to check, modify etc as I did in the past via a web browser will not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
understood.
But how are you trying to access it? Via mywifiext . net or using its ip address?
What error is it giving you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great, this worked - can access the extender as usual! Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
