× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6120 WIFI Range Extender not connecting to the 5GHZ signal from my Pace AT&T 5268AC Router
Mchamb70
I am able to connect to the router on 2.4GHZ but am having no luck connecting it to 5GHZ.. It is able to see it on initial set up but after that no luck.
Your session will time out in one minute. Would you like to extend your session for another five minutes?
Yes No
Your session timed out due to inactivity. Click the OK button to log in again.
OK
  • Hardware Version: EX6120
  • Firmware Version: V1.0.0.30_1.0.20
Connection to Existing Network (2.4GHz)
  • Signal Strength: 130 Mbps
  • Name (SSID): ATT7lzK6Br
  • Connection Status: Connected
Connection to Existing Network (5GHz)
  • Signal Strength: 0 Mbps
  • Name (SSID):
  • Connection Status: Disconnected
Extender WiFi Status (2.4GHz)
  • Name (SSID): ATT7lzK6Br_2GEXT
  • Region: North America
  • Channel: Auto ( 9(P)+5(S) )
  • Wireless mode: Up to 300 Mbps
  • Wireless AP: On
  • Broadcast Name: On
  • Wi-Fi Protected Setup: Configured
Extender WiFi Status (5GHz)
  • Name (SSID): ATT7lzK6Br_5GEXT
  • Channel: 149 + 153(P) + 157 + 161
  • Wireless mode: Up to 867 Mbps
  • Wireless AP: On
  • Hardware Version EX6120
  • Firmware Version V1.0.0.30_1.0.20
  • Connection Type Ethernet
  • Connection Status Connected
Access Point Wireless Settings (2.4GHz)
  • Wireless AP: On
Access Point Wireless Settings (5GHz)
  • Wireless AP: On
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: EX6120 WIFI Range Extender not connecting to the 5GHZ signal from my Pace AT&T 5268AC Router
Did you set up the extender beside the router and then move it to the location you are needing it in?
DarrenM
Message 2 of 5
Mchamb70
Yes, within 3 feet of it.
Message 3 of 5
mhackney
I am having exactly the same issue on an EX6120 I bought today. Same firmware version, all stats you show are the same. I have a FIOS router and every device in my house can connect on either the 2.4 or 5GHz networks I have configured.
I think I'll just send this back to Amazon, not worth the headache.
Message 4 of 5
KurtA
Initiate
Same Problem here.
I Send it back to Amazon.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3879 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
