× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX6120 as Access Point: DHCP server and WiFi channel select?
MarkLu
Hi,
I'd like to buy an EX6120, but need to check a copule of things before I do.
When configured as an access point, can it act as a DHCP server for devices that connect to its WiFi?
When configured as an access point, can I change the WiFi channel it uses on each band?
Thank you.
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: EX6120 as Access Point: DHCP server and WiFi channel select?
Hi @MarkLu,
Welcome to the community!
1. No, the main router will be the DHCP server.
2. Yes, the wireless channel can be changed when configured as an access point.
Dexter
Community Team
Message 2 of 4
DexterJB
NETGEAR Moderator
Hi @MarkLu,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 4
MarkLu
I can't buy the unit because I need one which includes a DHCP server - it's a device (live sound mixer) that I'll be plugging in to the wired Ethernet port rather than a network. Thank you for your help, and please feel free to close this issue.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1267 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
