- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6120 malfunctioning when heating - had it replaced and the new one malfunctions too!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
My EX6120 has been working fine for slightly less than a year, then it started misbehaving: it was randomly loosing the connection (and sometimes rebooting) every 10-20 minutes or even less.
I unplugged it, and it was quite hot. I let it cool down for a few hours, then plugged it again: it worked fine for about two hours, then restarted malfunctioning.
Had it replaced from Amazon last week, with a brand new one (box was sealed). Set it up as the older one, it worked five for just days!
Currently, the new one randomly:
- looses connection with the router;
- lets you connect, but doesn't give you access to the Internet;
- doesn't let you log into its own user interface (browser timeout);
- reboots.
This also happens with the repeater placed about ten meters away from the router, with no obstacles between them!
technical details (apply to both the old and the new EX6120):
- firmware updated to the latest available release
- always been connected to the same router ("Vodafone Station Revolution") and its configuration hasn't changed; devices attached to the router's WiFi (I mean without repeater) have a stable and working connection.
- connected both 2.4 and 5 GHz networks; same behavior;
- WiFi channels are the default ones, "WiFi Analytics" app states they are the best choice;
- Attempted both WPS and manual configuration: they all worked fine as long as the repeaters were working.
Anyone able to help me?
Or should I ask for another replacement?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rif.: EX6120 malfunctioning when heating - had it replaced and the new one malfunctions too!
oops...!
Sorry, "it worked five for just days!" was supposed to be "it worked fine for just five days!"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rif.: EX6120 malfunctioning when heating - had it replaced and the new one malfunctions too!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I haven't found a solution, but rather a temporary workaround.
I do need a stable WiFi connection for remote working, so I've connected the EX6120 to one of the router's Ethernet ports using a 10m long cable, and reconfigured it as an access point.
I've noticed that:
- it's still hot, but not overheating as much as it did when it was set up as a range extender;
- it doesn't seem to reboot any more;
- WiFi rarely drops the connection, though it still happens a few times per day.
Obviously, it's just a temporary workaround: having a ten meters long cable laid across my living room's floor is definitely not the best way to extend WiFi coverage!
Incidentally, WiFi signal strenght is still very poor; moving more than one single room ahead it's almost impossible to connect.
