× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6130 AC1200, I need to change the saved router's password
FrancoAgo
I've a wifi range extender AC1200 Model EX6130, i need to changhe the saved router's password,
how i must go on?
I'm sorry for my bad english
Message 1 of 10
Guru
Re: EX6130 AC1200, I need to change the saved router's password
The routers wifi password or the login to the gui?
If you need to change what ssid and password the extender is trying to connect to, connect to the extender either with an ethernet connection or the wifi. Then go to mywifi.ext and log into it. from there you can go through setup again to connect to the wireless.
Message 2 of 10
FrancoAgo
The routers wifi password, but i don't need to change the ssid only the password, i just noted that i've misstyped the password for the 5 ghz
Message 3 of 10
Guru
should be able to hardwire in or connect via the 2.4ghz. From there you can login to the extender and change the wifi settings.
Message 4 of 10
FrancoAgo
Yes I can login in mywifiext.net but i don't know as change the right setting
Message 5 of 10
Guru
page 12 of the manual. just redo the "new extender setup". It'll let you go back through connection to the router and wifi settings.
https://www.netgear.com/support/product/EX6130.aspx
Message 6 of 10
FrancoAgo
thank you for your time, but i've not new extender setup button, i suppose because is not a new extender
Message 7 of 10
Guru
so just reset the ex6130 back to factory (push and hold reset for 7-10 seconds while powered on).
then follow the new installation guide.
Message 8 of 10
FrancoAgo
Again thanks for your time, but i was searching a solution without a reset
Message 9 of 10
Guru
Message 10 of 10
Discussion stats
  • 9 replies
  • 1059 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
