× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6130 - Restriction d'accès selon plage horaire
Rod05
Bonjour à tous,
L'accès internet de mes enfants est possible sur certaine plages horaires enrgistrées sur la box.
En utilisant l'EX6130, j'aimerais pouvoir bénéficier de cette option.
Comment faire ? Merci.
Message 1 of 11
Guru
Re: EX6130 - Restriction d'accès selon plage horaire
(Sorry about using English, but that's all I can do).
You can set up an access schedule in the extender using the information on page 35 of the manual (https://www.downloads.netgear.com/files/GDC/EX6130/EX6130_EN_UM.pdf ).  But that affects all devices, not just the ones your children use.
Many routers will let you set up a schedule for each device though.  However, if your children's devices include mobile data, then you probably need to get a parental control app.
Message 2 of 11
Rod05
No matter. I wondered if I would get an answer to a french language message.
I just don't find this option. My interface is in French. And the french manual is different too.
How can i switch the interface language to english ?
Thanks
Message 3 of 11
Guru
I don't know, but I suggest trying to set your browser to English, and see if the web interface follows.
Message 4 of 11
Rod05
the switch to english is ok.
The subsections of Do More are :
- Wifi coverage
- Fastlane
- Connect Devices
That's all
Message 5 of 11
Guru
It's not an extender I own, so I don't think I can help figure out the discrepancy between the manual and the actual extender.
Are you running 1.0.0.24 firmware?
Message 6 of 11
Rod05
Hi,
The Firmware Version is V1.0.0.28_1.0.16.
Have a nice Sunday !
Message 7 of 11
Guru
It should be there.  Perhaps try resetting the router, and set it up again???
Message 8 of 11
Rod05
I have reset the router but there is no change.
Still have the same menu.
Does anybody know if this kind of option will be implemented ?
Message 9 of 11
Rod05
Access schedule works only in extender mode.
That is the reason why.
Nevertheless, it seems to me that I have to choose an extender/access point model that enable schedule option by material.
Do you know if there is such a product among Netgear extender ?
Thanks
Message 10 of 11
Guru
Sorry, I didn't notice that limitation.  I don't know why Netgear limits it that way.
If you don't need the extender mode, then maybe consider an access point instead (for instance the WAC505).  That will let you turn the wifi off/on per a schedule.  http://www.downloads.netgear.com/files/GDC/WAC505/WAC505_UM_EN.pdf
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1550 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
