- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6150 disconnect clients after a time period.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After installing two separate EX6150 as AP (access points) they both disconnect
Wi-Fi devices/clients, which are wall mounted and steadily fix’ed.
This behavior are observed after apparently one or two hours,
on both Wi-Fi band. (2.4 & 5 Ghz), or with single band operation.
The client requires manual reconnection to the EX6150.
The EX6150 have been reset to factory default and moved around at various locations,
but no more than a few meter from the clients and various Wi-Fi channels have been tested,
but the same behavior is observed constantly.
This is not observed on any other tested AP or WiFi-Routers,
with same clients and environment. (Asus, Zyxel, Cisco, D-link, and so on)
If this is a built in function it should be as an option,
if not, it should be dealt with as a bug and fix’ed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6150 disconnect clients after a time period.
Hi @SteinarGrande,
Can you please confirm the firmware version on the EX6150 and which router is connected to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Netgear support web page state there is one (1), fw, the initial. The router is irrelevant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @SteinarGrande,
You can try re-flashing the initial firmware onto the EX6150. Download the zip from the support page, unzip the .chk file and manually upload it to your EX6150.
See page 42 of 50: http://www.downloads.netgear.com/files/GDC/EX6150/EX6150_UM_7apr2015.pdf
Also try changing to WiFi channels that are less crowded, on the EX6150.
If you are still experiencing issues, please open a case with Support:
- Mark as New
- Bookmark
- Subscribe
- Permalink
it's already done, no solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have exaclty the same problem. I have tried 2 different EX6150 and both exhibit the same problem. After a few minutes, the connection to the devices drops. There is a hardware problem somewhere and Netgear is unaware of it. I upgraded the firmware on both devices and they do exactly the same thing.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
