× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX6150v2 – AC1200 WiFi Range Extender won't connect to router
mpen
Hey, my EX6150v2 AC1200 Range extender won't connect to my router. I have tried the WPS buttons on both as well as logging in via the installation assistant - the extender's Router Link LED has never turned green. I am out of ideas - pls help! My router is a Hitron CGNVM-3589 if that helps...
Model: EX6920|AC1200-WiFi Range Extenders
Message 1 of 5
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: EX6150v2 – AC1200 WiFi Range Extender won't connect to router
Hi @mpen,
Welcome to the community!
1. Are you getting an error during the setup process?
2. Please make sure that you are using the correct password for the router during setup.
Dexter
Community Team
Message 2 of 5
All Replies
DexterJB
NETGEAR Moderator
Hi @mpen,
Dexter
Community Team
Message 2 of 5
DexterJB
NETGEAR Moderator
Hi @mpen,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 5
mpen
Hi Dexter
Yes I was still getting the issue. I did some online research and apparently the Hitron router I have is notorious for not connecting to extenders. I have bought myself a power line adaptor which does the job. Thanks for following up!
Mike
Message 4 of 5
DexterJB
NETGEAR Moderator
Hi @mpen,
Thank you for the update and confirmation. Glad to know you got it working.
Dexter
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2928 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
