×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
EX6150v2 Issue Maintaining Internet Connection
adh15
Follower
Router: NETGEAR WGR614v10
Extender: NETGEAR EX6150v2
The extender installation went smooth using the WPS feature.  The extender functions properly except that everyday I have to power off/on the extender to restablish connection to the router.
For example, in the morning after powering on my laptop, I am able to visually select the extender from my WiFi connection, however after the connection is established to the extender, I am unable to access the internet.  I have to physically power off/on the extender for it to work properly in an effort to gain internet access.
Items that have been verified:
All firmware (router and extender) have been updated.
The appropriate connection to my router have been established (visually inspected the extender from router access).
Reset and installed extender a couple of different times in an effort to remedy the issue with no luck.
Any suggestions are greatly appreciated.
Thank you!
Model: EX6150|AC1200 WiFi Range Extender
Message 1 of 3
jvasanth1984
Virtuoso
Re: EX6150v2 Issue Maintaining Internet Connection
Hi @adh15,
                   Try to modify wireless channel on router and check if that helps.
Message 2 of 3
Dravo
Tutor
I am having the same issues have you found a fix?
Message 3 of 3
Discussion stats
  • 2 replies
  • 763 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
