× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
[EX6150v2] cannot get connected to 5GHz band of router
ldm1417
Hi,
The extender cannot get connected to my router with 5GHz band.
Other devices do canget be connected to the router on this band.
How to solve?
Here is my current configuration:
router to extender: 2.4Ghz band only
extender to devices: both 2.4GHz and 5GHz
How to make the extender to be connected to my router on the 5GHz band?
Thank you!
Model: EX6150|AC1200 WiFi Range Extender
Message 1 of 12
Guru
Re: [EX6150v2] cannot get connected to 5GHz band of router
What speeds are they seeing (perhaps test with speedtest.net)?
Message 2 of 12
ldm1417
I've just got connected to the router 5GHz band with Galaxy S5.
Download speed: 86Mbps, Upload: 3.23Mbps (very similar as with wired connection), distance to the router: 0.5m
Message 3 of 12
Guru
Are you seeing an error when you try to connect the extender to the 5 Ghz router network?
If so, what error?
Message 4 of 12
ldm1417
No, there is no error... The Extender Web Setup just says "cannot get connected to 5GHz router band". It cannot find the 5GHz SSID (other devices can find/see this SSID). Even I define this SSID manually, the Extender cannot get connected to it (other devices get connected to this SSID without any problem).
Message 5 of 12
Guru
What security mode is the router using for the 5G network?  Also, what channel(s) is it using?
 Are these other devices in the same location as the extender?
Message 6 of 12
ldm1417
"What security mode is the router using for the 5G network?"  - WPA-WPA2 Personal
Channel: Auto (64) - router can change the channel according to the changed envirounment/performance/... Could it be an issue? but the 2.4GHz band does the same...
"Are these other devices in the same location as the extender?" - yes
Message 7 of 12
Guru
It could be.  Try changing the channel on the router to 48 or 149.
Message 8 of 12
ldm1417
Why channel 48 or 149 should be more stable? The Internet Service Provider say that the router should be able to change the channels automatically according to the signal strength.
Message 9 of 12
Guru
Channels do vary by geography.  Channel 64 is a "DFS" channel.  WiFi devices that use this channel need to look out for Radar systems that also use it, and switch to a different channel if that's the case.  That's potentially something that could go wrong. Channel 48 and 149 are available in all geographies, and don't use DFS.
In Europe, channel 149 has a max power of 25 mw, so 48 might be a better choice there.
Message 10 of 12
ldm1417
The 5GHz band in my router is mapped to Auto(36) channel.
According to WiFi channels list (https://en.wikipedia.org/wiki/List_of_WLAN_channels) it seems there is no a difference between the channels 36 and 48...
Message 11 of 12
Guru
36 should work as well as 48.
Is it possible that the 5 ghz radio in the extender isn't working at all?  Are you seeing a 5 ghz client-facing network in the network list of your devices?
You could test this by setting up FastLane on the 2.4 ghz connection, and then the client-facing network would only be 5 Ghz.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2107 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
