palmdog70
Sep 30, 2024Follower
EX6150v2
Every time I reboot the router I have to reset the Wi-Fi extender. I have other extenders and they do not need to be reset. Is their a fix for this?
1 Reply
what router do you have?
What firmware is on the extender?
What method of setup did you use for the extender? WPS, the installation assistant, the app?
Try the installation assistant
