- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6200 FW:V1.0.3.68_1.1.104 AES encryption setting bug
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m using the EX6200 as AP with the latest firmware and I’m experiencing a strange issue: Both my Macs (One IMac 09 and one MacMini12 both with OS X 10.11.1) report “a” protocol link with 5Ghz and “g” link with 2.4Ghz. In both band speed is extremely slow.
I suspect that even if AES encryption is setted in the extender gui, TKIP is used. An easy proof of this is my main router reporting TKIP encryption on both EX6200 WLANs.
The only way to set AES is to choose both TKIP and AES but in my opinion TKIP is better when is set off.
I hope someone could forward this to developes in order to fix.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6200 FW:V1.0.3.68_1.1.104 AES encryption setting bug
Do you have any old devices that can only do 802.11g?
It's very strange to see a Mac using 802.11g. Can you try enabling 20/40 MHz coexistence on the extender? I have a feeling that it could be causing the extender to not behave well.
The RSSI at 5 GHz is terrible. It's barely above the noise level. Are Wi-Fi channels 100 and higher available in your region? The lower channels generally have low transmit power. At the very least, try to change to a different channel. Channel 60 could be congested.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 5ghz rssi now is 61db with 50% power transmit. The strange thing is that in the gui i cannot select channels over 46, I cannot figure out how channel 60 was selected. Btw rssi now is good also because while taking the screen the old 5ghz wlan was active and in the same channel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you KiccoLSD, TheEther for your feedback.
I'm forwarding this issue to support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you need my help to reproduce the bug or something else I'm happy to further help (I was in the beta team for the EX6200)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know!
I've forwarded information to support and engineering.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
