× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6200 Wireless Extender
Keith7
Hope someone can help with this simple I think question. I use a BT Home Hub 5 router, and am already using an EX6200 as a wireless extender and it works just fine. My question is can I buy another one to strenghen a weak signal elsewhere and connect to the same BT router? In other words not just connect one but two, is it straightforward?
Keith
Message 1 of 6
Accepted Solutions
Babylon5
NETGEAR Employee Retired
Re: EX6200 Wireless Extender
The EX6200 is a universal extender; it can work with a variety of base stations including those from other manufacturers. There should be no reliance on any particular features of the base station and the EX6200 should effectively appear as a client device to the base station. You should therefore be able to associate more than one extender with the same base station; I have done this in the past with an EX6200 and an EX7000 without any issues.
I think that’s what you are asking in your post 1, and you are not suggesting base station to EX6200 to EX6200 i.e. daisy-chained? That would result in very poor throughput at the most distant client devices.
Message 5 of 6
All Replies
netwrks
Master
I think in theory it can be done. There are a couple of other similar posts around, but one thing will be certain, throughput on your network will be abysmal..
Message 2 of 6
Keith7
Thanks very much for your reply, it certainly sounds not a good idea.
Keith
Message 3 of 6
Keith7
Whilst I am very grateful for your reply  still do not have an answer to my question and want to know the answer. I am now being asked to accept a solution yet dont have an answer what do I do next?
Kind regards
Keith
Message 4 of 6
Babylon5
Message 5 of 6
Keith7
Thank you so much.
Kind regards
Keith
Message 6 of 6
Discussion stats
  • 5 replies
  • 4291 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
